amp could it be faulty( sound problem please help)
Discussion in 'AV Receivers & Amplifiers' started by monitor, Feb 1, 2002.
  1. monitor
    monitor
    as mentioned i i have sound problem and can,t solve it.
    When i noramlly listen to dvds i use my amp and mute the TV sound
    recentley i have been noticing that the(speech) sound in general fom the centre channel seemed low.
    so while watching swordfish i alternated between my amp centre channel and my tv sound playing all centre channel sound
    the sound from the tv had much more background to it and i could hear things that were not ther when coming through the amp the speec levels were better and generally ab better center channel sound
    My thoughts about the problem are as follows
    could i have a faulty speaker ( seems ok with the test tones)
    or i recentley hacked my dvd its a philips ( using the standard philips hack) do i need to do somthing else in the set up menu
    could it be my channel levels i have played around with them to no avail
    Any help or advice would be great , i have just got 5 new dvds but don,t want to watch them until i get this sorted.
    my system
    philips DVD958
    denon AVR-F100 amp
    denon NXT flat panel speakers
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,575
    Somewhere in South Yorkshire
    +6,095
    It could just be the software; don't know this film but maybe the centre channel mix is a little light. If the problem has begun to appear with other titles too, then.....
    You could begin to narrow it down, by exchanging your centre speaker for, say, the left hand front one. If the problem moves to the left, suspect the speaker.
    Otherwise, suspect either the cable or the amp.
  3. seq2
    seq2
    have you got your centre channel setting set as normal.....ie....normal gives a big sound, wide mode gives hardly any sound,................phanthom uses no spkr obviously.
    is you spkr cable the right way.......in phase.......
