Amp buying advice needed (>£300)
Discussion in 'AV Receivers & Amplifiers' started by CarbonToe, Jun 15, 2005.
  1. CarbonToe
    I currently have an aging Kenwood Pro-Logic amp, a DAC Magic 2 Mk2, a Cambridge Audio CD6 and a Roku M1000 media server.
    This lot takes up far too much room hence the DAC and CD6 being for sale on eBay at the moment!! The Amp will follow soon as I have a replacement.
    The replacement needs to meet the following criteria:
    1. Must have Digital Optical or Coax input to connect my Roku M1000.
    2. Be able to connect two lots of speakers (a pair of B&W DM601 for inside and B&W WM4 for outside). If I could choose from A, B and A+B all the better!
    4. Be small form factor, as the Roku is only 12 inches wide and will sit on the top.
    3. Cost no more than £300. If a decent cheaper amp is available – great!!
    Thanks for your help.
