Amp and sub settings
Mulder79
Iv had the follwing set up for a few months now but still dont feel like im getting the best results from it
Kef KHT1005 and Sony 1200es AV receiver..
i think my problem is the Kef SUB settings.. can anyone tell me what settings they have their sub on so that i can see what i am doin wrong plz
dunamis
Not sure that I can offer much help but if you describe a bit of why you don't feel you're getting the best from it and what your current settings are it might prompt some other replies?
Ronnie
CasDon
Mulder, these are what I have my KEF 2005.2 sub set to.
Phase - 0
Glide - 24db
Crossover - max
Input - about 10 degrees from 0
My yamaha amp cross over is set to 80hz which I believe is the lowest frequency that the satalites will go to, so this means (in theory) there shouldn't be any gap in the frequency range.
