Amp Advice Deperately Needed
Discussion in 'AV Receivers & Amplifiers' started by mabell, Aug 19, 2005.
  1. mabell
    mabell
    Jul 26, 2005
    134
    Tunbridge Wells
    +5
    I really need some help choosing my final purchase (for now at least!), an Integrated Amp/Receiver, which I can connect all devices to.
    - 25" Sony (Scart Only)
    - Sanyo Z3 Projector
    - ORB Audio Speakers (3 x Mod2, 2 x Mod1) - being delivered next week
    - Sky +
    - XBOX
    The amp will be used mainly for tv,movies and possibly music depending on how good the ORBs are (Ive read good things). So really, an all rounder is required my budget is up to £300, I have looked at the Yamaha's and the Cambridge Audio Azur 540R.
    First Question: What would you recommend?
    Second Question: How best can I connect all of the above?
  2. mabell
    mabell
    Jul 26, 2005
    134
    Tunbridge Wells
    +5
    My XBOX is modded, and I have the official Hi def AV Pack.
    And I will also be buying a Sub for the speakers, next month probably.
