I have a problem with satellite reception. With the centre core of the coaxial cable inserted I have perfect reception, however as soon as I attempt to screw the "F" connector to the unit I lose the signal. It seems that the signal is being shorted to ground. Same cable works perfectly on my other Sat receivers.
I suspect the tuner module which I might replace when if I can find one.
Has anyone else had a similar problem?
