American Sub
Discussion in 'Subwoofers' started by stonking, Mar 30, 2005.
  1. stonking
    stonking
    Dec 17, 2004
    383
    Godstone, Surrey
    +5
    Hi all. I might buy a sub second hand from the US. Troble is it's 120v 60 hz. Is there a handy transformer that anyone knows about to fix this? Does the 60Hz bit really matter?
    Regards
  2. kbfern
    kbfern
    Aug 17, 2002
    17,781
    Wolverhampton
    +5,950
    The transformer will depend on the wattage that the amplifier uses,butyou can get step down transformers from Maplin and other sources in the UK.
    I would think that you would need a transformer of at least 200/300 va(volt amps) but as I said this depends on the amp in the sub.
  3. kbfern
    kbfern
    Aug 17, 2002
    17,781
    Wolverhampton
    +5,950
    By the way I have a US sub made by Atlantic Technology (bought while I was living in the US) and the voltage is switchable.I would check, yours may be too.
  4. rOAdeh
    rOAdeh
    Jan 24, 2003
    648
    Winchester
    +5
    Getting a decent transformer that has a clean output that can supply your sub with enougb power during even the most difficult transients may prove both difficult and expensive.
    Definitely something to look into properly before plunging in with both feet
  5. stonking
    stonking
    Dec 17, 2004
    383
    Godstone, Surrey
    +5
    Thanks for the prompt replies. I have checked and it does not have a 120V 240v switch. As for clean supply, I have no idea. I think transformers are quite good (no moving parts). Any views on the 50 / 60 hz bit? Does a transformer change that as well?
  6. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    And also could give rise to the dreaded hum too
  7. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    It really depends on how well designed the power supply is. The transformer is unlikely to change the frequency unless you buy a complete regeneration unit which is very expensive.
    Using a 50Hz unit on a 60Hz supply should cause no problems at all but using a 60Hz unit on a 50Hz supply can lead to a substantial amount of mains hum. Naturally, Americans have never noticed this (since imported stuff to there will work fine) but it can be a problem here if the designers didn't consider it. :)
  8. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    I dont think the 60hz is an issue unless the gear has motors...
    Actually I brought a complete system from Canada 20 years ago, and used it with a transformer for many years...
    The transformer was a bit noisy because I had to have a really big one custom made to handle the McIntoshes... :rolleyes:
