Answered American product voltage
Discussion in 'General Tech & Gadget Forums' started by pcaddy, Jun 13, 2018.
  1. pcaddy
    pcaddy
    Dec 3, 2010
    461
    4
    Folkestone Kent
    +423
    I wish to buy an "Aircom T9, AV component cooling fan system" and wondered if anyone can help with the electrical connection. It says under technical specifications that it uses "Wall Adapter Input 100 to 240V AC" if I understand it correctly this will be OK to use here in the UK with an UK 3 pin adapter. I would like to know if I am right. Help would be appreciated.
  2. Best Answer:
    Post #2 by John7, Jun 13, 2018 (1 points)
  3. John7
    John7
    Aug 6, 2004
    2,742
    +925
    Best Answer
    Most modern devices have a "universal" input voltage adapter which will work within the voltage range stated, so it will be OK for use on UK supply with a suitable plug adapter.
    • Thanks Thanks x 1
    • Agree Agree x 1
    • List
  4. Trollslayer
    Trollslayer
    Feb 11, 2007
    24,292
    Poole
    +9,580
    John is correct, this is quite common.
  5. outoftheknow
    outoftheknow
    Nov 1, 2012
    3,800
    Canberra, Australia
    +1,346
