american portable dvd players
Discussion in 'Movie Forum' started by fatherofnight, Dec 1, 2002.
  1. fatherofnight
    fatherofnight
    Sep 6, 2002
    755
    Hartlepool
    +47
    hi
    can anyone help with this inquiry, i am looking to buy a portable dvd player and have noticed that they are cheaper in the states, does anyone know if there is a problem re battery charging or anything else that might present a problem.
    any help will be appreciated.
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,815
    Somewhere in South Yorkshire
    +5,025
    1: Mains voltage for power supply/battery charger. Probably unusable in UK without a transformer (unless it is a multi-voltage job).
    2: Probable that the player will only reproduce NTSC - ie will NOT play any European or Australian (etc) PAL discs - irrespective of region coding.
    You can only check out the specs. of the US version to find out.
    3: May have difficulty getting the player modified for multi-region even IF it can reproduce PAL.
