American Plasma displays.
Discussion in 'Plasma TVs Forum' started by Gurn, May 5, 2005.
  1. Gurn
    Gurn
    Would anyone know if I imported a plasma screen from America (at a greatly reduced price), Would it work in the UK?
    I would connect it up to a Pioneer VSX-2014, using component leads.
    Do the psu's auto sense for 110 / 240 v?
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    Some do, some have a switch and some dont. Research needed there I think. Your major issue is warranty, you won't have one with a US product. EC is different, by law it covers all EC countries, not so with US. The other problem is that whilst they look cheap in USA, when it gets here customs will have their wicked way with your wallet.... VAT, import duty and on top of all that, 14% levy on any DVI/HDMI equipped TV/panel. Add that up, and the drawback of no warranty, and you may well find it best to buy in UK
  3. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,357
    63
    East Yorkshire, England
    +171
    Also dont forget how fragile plasmas are.
    You wont be able to open the box until after you have paid all the Duty, VAT clearance fees etc.
    Imagine the hassle if after paying all that the screen is cracked.
    When the replacement arrives you might have difficulty with customs charges again unless the supplier has made it clear on the paperwork why another was sent.
    You can be sure a plasma in a box is going to be dropped on the way!
    Not a chance I would take with a plasma and a few thousand £.
    Mark.
  4. Gurn
    Gurn
    I live in Guernsey, so will not have to worry about VAT or import duty etc.
    I also will have to get the plasma shipped to me anyway, so will have to take the risk on damage either way.
    This is why I was interested in the workings of the display.
  5. fatherted
    fatherted
    Mar 6, 2005
    87
    Hampshire
    If you're not worried about VAT, then I would buy in the UK.
    If buying in the US then I would make sure it is strapped to a pallet, that way it will not tip over.
    Shipping would be expensive, due to the volumetric weight. If you don't know how this works, basically shipping an empty box will cost the same as a heavy box. It's all down to the actual size the item uses up in the cargo hold, and the shipping co's have a calculation for this.
  6. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,357
    63
    +171
    Lucky you !
    I would still buy from a reputable dealer in UK who can send to you without VAT, will be much less hassle if you have problems.
    Depends how much you will save of course.
    ( I have seen how pallets are 'handled' by air freight companies, I would risk a subwoofer import from USA but nothing with glass)
    Mark.
  7. is1111
    is1111
    Mar 17, 2005
    1,564
    63
    +213
