Quantcast
American DV 27-help!
W
wavimm
I'm going to import the fmj 27a from the u.s.
Does the american have the scart contact?
and does it work with 230/50w?
Thank you!
ari from norway.
StooMonster
Norway's not in the EU, so wavimm would have to pay VAT and Import Duty buying from either USA or EU; although his shipping would be cheaper.
StooMonster
buns
oooops sorry..... id still like to think from UK would be cheaper though..... after all there isnt the US distributor getting the cut and in theory the vat wouldnt have to be paid for th UK.....
ad
mjn
Norway is not in the EU?
Don't they use the €?
StooMonster
Of course they don't use Euro as their currency if they are not in EU, they use Norwegian Kroner.
Ah... I've spend many months on several occations working in Norway (Oslo, Stavanger, Trondheim): beautiful country, can be cold (-40C or -40F is really cold), no night in summer and no day in winter, Auroras light up the sky, expensive drinking, fjords, hering, football obsession, skiing, etc.
Nope, not in EU and never have been. http://www.aksess.no/nteu/eng/ will fill you in.
StooMonster
mjn
so they're not!
Anyway, will an USA 27 play NTSC AND PAL?
Also doubt there will be a SCART.
buns
Ive never really considered this before..... but at a guess id not imagine there to be any physical difference...... after all arcam are a smallish operation and even smaller in the US...... i'll be interested to hear the truth
ad
RaceTripper
Looks like this never really got answered, so maybe this will help...
I'm in the US and have a DV88 Plus. It has the Scart connector, and all the PAL selections available in the setup menu. There's also a switch to set supply voltage between 110/220. I'd bet the DV27 is configured similarly.
So getting a US model to work probably means setting the voltage switch, accessing the service menu to configure region, and getting the appropriate power cable.
Dean
sticker
Top man Dean :smashin:
