american camcorders
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by indio uk, May 26, 2003.
  1. indio uk
    indio uk
    May 26, 2003
    27
    i am of to the usa soon and had planned to buy a new camcorder, what are the pitfalls of doing this?
    i understand there could be a problem if something goes wrong, but what about the pal or ntsc format? are pal format camcorders readily avalible in the usa, if i bought an ntsc format one, how do you watch it on a tv and record to video tape with it .
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,311
    Rainham Essex
    +2,425
    You can get PAL camcorders in the USA, but not as easily as an NTSC. They are also more expensive than an NTSC model. In the large tourist areas you should have no problems finding PAL models.
    Check that the cam has a worldwide guarentee, so it can get repaired in UK if needed.
    Most modern TV's & VCR's can play back NTSC video, but the quality is often lower as it is just an analogue conversion useing lower cost components. You can convert NTSC to PAL on a PC in software if editing on a PC. This will give a far higher quality conversion.
    Be aware though that bringing a camcorder back into the UK you can be charged VAT & inport duty if caught.
    Mark.
  3. indio uk
    indio uk
    May 26, 2003
    27
    thanks mark
    whats the best software for the pc?
