Hello everyone.
I have just put together my new amd llano setup. I am having problems getting it to boot though. I think it may be a problem with the PSU though.
I got a GByte GA-A55M-S2HP
AMD Lanno A6 the tipple core one
Patriot SSD
DVD Drive
2 Fans
Now the reason I think it is a PSU problem is because I have tried another psu which is 150w, the system boots and I can change bios settings fine. The one in my new build is a 400w Antec High current psu, when I use this the fans spin for a few seconds, the cpu fan sort of judders a bit like its trying to start up then everything then dies. I have to manually turn off the psu with the switch for a seconds before I can attempt a reboot again.
I have jumped the power supply and that seems to work fine. Is there sort of a minimum wattage which must be applied in order to boot the PSU? Maybe my new build isnt drawing enough power and its turning off. Any help please guys im going crazy
Patriot SSD
DVD Drive
2 Fans
