Ambient light kit question
Discussion in 'Home Cinema Buying & Building' started by CJSIMPSON, Feb 9, 2014.
  1. CJSIMPSON
    CJSIMPSON
    Jan 17, 2006
    756
    +4
    I have a 55inch LCD TV and I am looking to install some ambient lighting after seeing a hi tec unit with lighting built in and was really impressed.
    I have seen the following kit and wondered if anyone could recommend this or advise a better solution for my needs.
    Remote Control Flexible RGB Strip Light Kit 5m by SimplyLED
    I would like the ability to dim and to alter brightness and this will be mounted to the rear of the tv.
