Amazon "Used" items - safer then ebay?
Discussion in 'Blu-ray & DVD discs' started by shaithis, Jun 3, 2005.
  1. shaithis
    shaithis
    Feb 25, 2005
    1,668
    The Last Aerie
    +31
    I was wondering if anyone had any experience of the used items on Amazon?
    Specifically are you more/less likely to get a pirate? Are you more/less covered then ebay?
    Any opinions would be most appreciated :)
  2. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,391
    +850
    i've used it a couple of times, just be wary and remember if it sounds to good to be true, it usually is!
  3. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    i used it a few times for dvds and got them, then ordered a phone (about a year or two ago) - a sharp gx20 for £170, and it never came. However they did give me a refund within a month of the purchase, so it would seem some are slightly dodgy, but you are well covered. :)
  4. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,628
    2
    In a secret location with Jennifer Lawrence
    +9,348
    Yes, you are well covered. The purchases actually go through Amazon, you pay them and then they pay the seller. As chedmaster said any problems and you should get a refund.
