Amazon US and Region 1
Discussion in 'Blu-ray & DVD discs' started by villaceltic, Oct 5, 2003.
  1. villaceltic
    villaceltic
    May 22, 2003
    84
    Nantwich, UK
    Just a quickie ( and apologies if it's been covered).
    Looking at Region 1 DVDs from Amazon.com (Finding Nemo for e.g.), they state within the details that the disk will PROBABLY not work in other regions. Are they just covering their backsides with a blanket statement on Region 1 disks or is it that I've just happened to be looking at ones that have some form of Region encryption that will prevent them from working on multiregion players? I have read about some studios encoding the disks in a way to make them unplayable in other regions - the fiends!
    Macca
  2. Drunken Master
    Drunken Master
    May 12, 2001
    837
    In the middle of a roundabout
    +7
    Yeah, Amazon are covering there backs.
    There are a lot of cheaper options available than using amazon! check out the recomended retailers thread.
  3. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    This very rarely happens... if you do a search on here I am sure you will be able to find a list of all the films with extra (RCE) encoding on them. From the top of my head I remember that they were mainly Columbia Tri-Star title such as MIIB , Spider-Man & Hollow Man...
  4. Daneel
    Daneel
    Dec 5, 2002
    2,843
    68
    London
    +8
    Manly multi-region DVD player will cope with RCE anyway. You can normally find this stuff out on the web. RCE isn't exactly advanced protection technology, IIRC it asks your DVD player if it will play R1, it it says yes it then asks if it will play any other regions, if it says yes then it will refuse to play the disc.
