Amazon Prime Video - buffer problem
Discussion in 'Film & TV On Demand Streaming Services' started by Jah45, Apr 8, 2018.
  1. Jah45
    Jah45
    Apr 8, 2018
    2
    4
    Maroc
    Hello,
    I got Amazon Prime Video on a Smart Sony TV and a PS4 with the Amazon Prime Video Application.
    When I try to watch anything, the picture is so bad quality, i got buffer problem.
    On the stream, i haven't HD logo when i start video, then 5 minutes of stream, sometime, i got HD logo, then poor quality, etc..
    I got an internet fiber 250/250mbps.
    I don't have this buffer problem on netflix for example.
    Has anyone else had a similar experience, and if so, were you able to fix it?
    Regards
  2. Clem_Dye
    Clem_Dye
    May 8, 2006
    3,527
    +534
    How are you connecting the TV to the Internet? Does your TV have up-to-date firmware and apps.? Have you tried a factory reset on the TV, or an external device with the Amazon app. installed that you can try by way of comparison?
    Clem
  3. Jah45
    Jah45
    Apr 8, 2018
    2
    4
    Maroc
    my Tv and PS4 are connecting on internet by cable directly to my box.
    my Tv and PS4 have last firmware
  4. Clem_Dye
    Clem_Dye
    May 8, 2006
    3,527
    +534
    Then try something on an external box to see if that makes a difference.
    Clem
  5. dib
    dib
    Mar 15, 2005
    44
    +11
    I have the same problem, very poor quality picture, sub vga. Firesticks are fine, 1080p after a minute or two, but the Panasonic app is rubbish.
    It used to be fine but seems to have a real problem recently.
    All the streams are across WiFi giving 10mbs at the TV.
    I would say it's an app issue.
    The iPlayer app has had problems in the past.
    I haven't tried an Ethernet connection as that's never going to be along term solution.
    I may try a factory reset on the TV.
    Good luck finding an easy solution.
    Dave
