Witterings
If I'm using a tablet / phone and want to cast Amazon Music to either a Chromecast Audio or an Alexa Dot / Input (both plugged in via analogue) does anyone know which should be better quality?
I'm guessing if you cast to Chromecast from a tablet / phone, the quality may depend on the device you're casting from as in essence it's relaying it from the device you're casting from .... although the Chromecast has the built in DAC.
If you cast using the Amazon App connected to a device, I believe it's not the phone that's actually doing the casting it's just instructing the connected Alexa device to cast instead.
Does anyone know which should be the higher quality and is it dependant on the device you're casting from?
