Jules Tohpipi
The Quest
Listen to Amazon Music HD and Ultra HD via a digital input (e.g. a DAC or digital input on an amplifier) ... whilst... wait for it... preserving the original Amazon streamed bit depth and sampling rate.
My quest has been mostly fruitless so far, even though my DAC accepts digital signals up to 24 bit and 96kHz (and will report the incoming sampling rate)
The Issues
These are in no particular order. All in the context of transferring a digital signal to a DAC.
1. Amazon Music HD app on iPhone
- Chromecast Audio: The CCA refuses to appear in the devices list hence casting from the Amazon app is not an option. Spotify casts fine to my CCA at 44.1kHz
- AirPlay on Apple TV: Amazon states AirPlay is constrained to a 16-bit signal max, so you can forget about Ultra HD. You can also forget about 44.1kHz because all Apple TVs (for example) output everything at 48kHz
2. Amazon Music HD desktop player (for Windows computers)
- Zero AirPlay or Casting options as far as I can see
- Suppose I could use a digital cable to my DAC but my laptop doesn't have a digital output - nor do I want to use a cable
3. Amazon Music Web Player
- When using the Amazon web player all mention of HD or Ultra HD disappears from the interface. So what you are hearing is your guess!
- Used in Chrome browser, this allows me to cast to the Chromecast Audio. But there's glitching every few seconds and the DAC reports all tracks at 48kHz (not 44.1kHz)
SUCCESS! (sort of, maybe not)
4. Amazon Music HD app on Android
My work gives me some Android phone thing, so in complete desperation I installed the Amazon Music app on it.
- Yes, I can cast to the CCA at 44.1kHz (as reported by the DAC). Hurrah!
- But it won't cast at Ultra HD quality. Try that and the yellow Ultra HD symbol in Amazon's own app gives you a little wink and drops down to 'HD' instead. But HD might actually mean SD if you read here.
Conclusion
Well, I'm a bit lost really. Had been hoping it was going to just work. Was looking forward to listening to Ultra HD. The above has somewhat taken the sheen off the otherwise good news from Amazon.
The Issues
Conclusion
