Amazon Fire TV Stick 4K
chinkw1
I just ordered an amazon Fire Stick 4K (2018), ETA on Tuesday.
1. Does it come pre-installed with HBOMAX?
2. Currently, is HBOMax already available in Amazon Apps store? (i read somewhere that HBOMax is not).
3. I intend to plug tv stick to my DENON X4000 AVR. Any thing or settings that I should look out for?
Thanks, new user is always excited. 😊
-gonzo-
I’d doubt it would be preinstalled, however HBO Max is a US only service so you’d need a VPN or smart dns to use it outside of the US.
chinkw1
Hi gonzo,
Yes I m using vpn.
Do u have any clue for question 2 & 3 pls?
Fire TV Stick 4K can be plug ti AVR direct?
-gonzo-
Not really as don’t use one myself.
However if it’s a UK device then it’s very likely that HBO Max wouldn’t actually be available in the UK Play Store.
mitch
Hi gonzo,
Yes I m using vpn.
Think you have to mess around with your address on Amazon.com and get it from there it will then pop up on your fire stick.
Toon Army
I have a 4k Firestick plugged directly into a rear hdmi socket on my X4400H. Only setting on AVR required is enhanced video under video settings.
dion 6
Its not in the apps store because obviously its a US app not a UK one but it can be side loaded just Google how to side load HBO Max on a 4k firestick and there's loads of instructions on how to do it
Stan Hope
can i semi hijack this thread...{sorry @chinkw1 hope you've gotten the advice you needed}
i'm getting a Q95T delivered on tomorrow, would i really need a 4k firestick ? currently only £26.99, but even at that price, is it something i need, and if so why ?
oneman
I've posted on the fire tv thread.
