Quantcast
Amazon.ca
T
TheGreatLordOz
does anyone know any codes for amazon? the $5 of has just ended and i need it so i dont get stung by customes so if there are any others now, or if any start soon can you post them here.
blaze
MAPTELUSFEB5 - $5 OFF (No minimum, Expires 15 April)
MAPETRADECAN - $5 OFF (No minimum, Expires 31 May)
MAPSCTELE5Q2 - $5 OFF (No minimum, Expires 31 May)
smiler
Have you tried using the $5 coupon that expires today, usually they include todays date and surely it'll still be today until about 6 in the morning because of the time difference. :)
On thedownside, the delared value is usually before coupons are taken into consideration so you'll still run the risk, although, it has been said by others that if you include a gift message sometimes the value is not printed on the front of the package.
Smiler
T
TheGreatLordOz
as these are two different codes MAPETRADECAN - $5 OFF (No minimum, Expires 31 May)
MAPSCTELE5Q2 - $5 OFF (No minimum, Expires 31 May) can you use them both?
