TV = 2020 Hisense 55” UHD 60Hz
Need advice from the Gurus
Settings:
/1/ I set the Display on the Firestick @ Automatic (up to 4K Ultra HD).
/2/ In the Firestick’s Developers Tool Menu, I activate Advanced Options (AV).
Issue
How do I keep the Display permanently at 2160 60Hz?
Is the BTSports App triggering this change if so why?
Regards
John
Settings:
Issue
- When streaming UHD with Netflix and Disney+ (both with UHD subscriptions) then AV shows 1080.
- Changing the Display to 2160 60Hz then streaming UHD with Netflix and Disney+ (both with UHD subscriptions) then AV shows 2160.
- If I then stream BTSports App (not 4K subscription) then the AV shows the display has changed to 1080 with Netflix and Disney+and Display on the Firestick to @ Automatic (up to 4K Ultra HD) and does not revert to 2160 60Hz i.e. displaying UHD with Netflix and Disney+, unless Display manually changed.
Regards
John
