Amazing 37" LG RZ37LZ30 LCD price: £2132. Any reviews?
Discussion in 'LCD & LED LCD TVs' started by jrecampbell, Sep 27, 2004.
  1. jrecampbell
    jrecampbell
    May 14, 2004
    56
    http://www.tvandvideodirect.com/product.php?xProd=1078
    LG RZ-37LZ30
    My local dealer (who only main deals for Loewe and Sharp) said that the only other make he would happily order in on demand was LG as they are terrific panels (that power Philips screens) at sensible prices. He would often couple it with something like a DVDO iScan HD for more picture processing bells and whistles if required. With a hi-res source he said it was as good as anything for a fraction of the RRP.
    I've not seen one and had my heard set on the 37" Sharp Titanium, but the LG could be a steal if the reviews of it's artifact-less smaller siblings are true (http://www.homecinemachoice.com/whatvideo/).
    Auto Volume Leveller Yes
    Brightness 500 cd/m
    Child Lock Yes
    Consumption 180W
    Contrast Ratio 500:1
    D/W Yes (1 + 3)
    Dimensions
    (WxHxD) with Stand 1081X 665 X 246
    Weight (Kg) 32
    Frequency
    Front Interface
    S-Video 1
    Function
    Child Lock Yes
    Sleep Timer Yes
    Teletext 2000 page
    H/Phone Jack -
    Interface
    H/phone Jack -
    PC Audio in 1
    Scart 2
    Source 110-240V 50/60Hz
    S-Video 1
    LCD
    Brightness 500 cd/m
    Pixel Format 1366x768
    Size 37" (94cm)
    Viewing Angle 176 degrees
    LCD Part
    Brightness 500 cd/m
    Size 37" (94cm)
    PC-In (D-Sub15 Pin) DVI-D
    Progressive Scan Yes
    PIP (PC/TV) 2 Tuner
    Power
    Consumption 180W
    Rear Interface
    S-Video 1
    Side Interface
    S-Video 1
    Sound
    Stereo/SAP Nicam/A2
    Stand-by < 3W
    Zoom In/Out Wide/Zoom1/Zoom2
    The only problem I can see is no component inputs (not even through DVI as DVI-D not I). However, the DVI input in the manual lists all the WideXGA (CVT) resolutions including 1366x768 @ 60Hz. So, the monitor underpinnings of the panel could be great for HCPC owners?
    There seems to be another generation coming with the LG XD Engine processing system (like Pixel Plus I guess), but in the meantime this could be a steal.
    Anyone seen one (or indeed the 42")?
  2. masher
    masher
    According to the manual the 30 inch has component in - it would seem strange if it's larger siblings wouldn't :confused:
    Cheers Mash
  3. alscds
    alscds
    be careful lg,s suffer from serious lip sync especialy 30"
