Wanted AM2 Compatible Heatsink/fan CPU Cooler
Discussion in 'Archived Classifieds' started by daws0n, Jun 25, 2015.
  1. daws0n
    daws0n
    Apr 28, 2006
    842
    28
    Gwent
    +27
    I've got my knock-up HTPC up and running with a passive HID 2600 Pro GPU and an AMD x2 4400. So far so good but my temps are very high with the stock cooler (I think it may have been for a lowered powered CPU). Temps are reaching 65-70 under general use so better cooling is definitely needed.
    Space is limited in this smallish case so nothing tall will fit. Does anyone have something that would fit the bill? Preferably quiet with 4 pin fan / copper based heatsink.
    ______________________________________________________
    This message is automatically inserted in all classifieds forum threads.
    By replying to this thread you agree to abide by the trading rules detailed here.
    Please be advised, all buyers and sellers should satisfy themselves that the other party is genuine by providing the following via private conversation to each other after negotiations are complete and prior to dispatching goods and making payment:
    • Landline telephone number. Make a call to check out the area code and number are correct, too
    • Name and address including postcode
    • Valid e-mail address
    DO NOT proceed with a deal until you are completely satisfied with all details being correct. It's in your best interest to check out these details yourself.
  2. OverclockedLoon
    OverclockedLoon
    Aug 15, 2014
    577
    +21
    scythe zipang 2 here was running it passive using an Athlon x2 250 and had issues with it am2/3 are the same mounting
  3. daws0n
    daws0n
    Apr 28, 2006
    842
    28
    Gwent
    +27
    How much?
  4. OverclockedLoon
    OverclockedLoon
    Aug 15, 2014
    577
    +21
    £10inc but dont have the fan or the fan mountings as i through them out years ago
  5. daws0n
    daws0n
    Apr 28, 2006
    842
    28
    Gwent
    +27
    I'll need to see if fits first as it looks pretty big on stock photos. I'll check tomorrow after work and get back to you?
  6. daws0n
    daws0n
    Apr 28, 2006
    842
    28
    Gwent
    +27
    Not suitable unfortunately I need something that supports retention clip mounting.
  7. DavidMac
    DavidMac
    Aug 18, 2009
    1,321
    +271
  8. daws0n
    daws0n
    Apr 28, 2006
    842
    28
    Gwent
    +27
    Thanks David - if there's enough clearance that'd be an ideal choice.
    I've fished out an old copper based ak856 from. 939 board. That should help in the mean time.
    These amd chips run quite hot it seems!
  9. DavidMac
    DavidMac
    Aug 18, 2009
    1,321
    +271
    I'm currently using it in a htpc so it should fit the bill for you in terms of height clearance.
  10. OverclockedLoon
    OverclockedLoon
    Aug 15, 2014
    577
    +21
    It has the retention clip mounting
