AM signal not working
Boro22
Would anyone know why my AM signal in car is not working. FM works fine.
Is there a different connect that I am not aware of? ie aerial is fine, and solitary aerial conenction on back of head unit is fine.
Julie
No, AM & FM use the same aerial in all car audio units. It's most likely to be a fault with your head unit I'm afraid.
Boro22
It cant be, as it has happend with 2 differents HUs now....
Boro22
can anyone help?
Boro22
anyone?
zircon3035
I fitted a new head unit last weekend and I also now have no AM reception. Mind you, FM is also a bit weaker than before. I'm beginning to wonder if the antenna is amplified and the new head not is not powering it. Another job for the weekend.
Boro22
I have checked the attenae behind head unit already, and it seems fine. As I said, happpened on 2 different head units now so so strange!
Let me know how you get on.
Aerojon
what car is it???????
alot of aftermarket headunits don't have power wire to supply the amplifier..
Boro22
It is a Honda Civic. Supply what amp? my seperate amp?
in ref to your signatory. has SAAB gone under?
