ReflexReact
Looking to buy a 65" gaming 4k TV this weekend, but I have an older non-4k amp so I want to make sure the TV I buy has a smart hub which allows me to have all my HDMI connections run into it, and then the audio signal pushed back to my amp via optical. It looks like most mid-high end 4k TVs now have one of these hubs?
Top of my range (and only if there are some good sales) are the OLEDs; namely LG B7 and C7. I only have £2000 max budget, ideally not to spend all of it - do these have the cable management hub, and are they OK for gaming?
Mid of my range is the Samsung MU8000's. These I know do have a cable hub thingy, and I believe they're pretty good for gaming? I suspect I can pick up one of these LED TVs in 65" flavour.
Another options is the Sony KD65XE9005 - I believe this may be considered better than the MU8000? But then again it's a bit more... is it worth the extra money?
What TVs am I missing here? I'm very keen on outstanding HDR10, low input lag for gaming, and then the smart cable hub thingy!
