am i gonna regret this or not?
Discussion in 'General TV Discussions Forum' started by goonie007, Mar 4, 2002.
  1. goonie007
    goonie007
    finally took the plunge and rang www.empiredirect.co.uk and ordered myself a jvc AV28WFT1 widescreen tv,they said it will be despatched today(monday)and will be here on wednesday is this company generally good to there word anyone had problems with empire direct,they seem genuine enough and there prices are way cheaper than the high street.also anyone had any problems with the above t.v set the 32inch model got rave reviews so i cant see how the 28inch model is gonna differ it did look good though when i saw it in dixons the other day all comments appreciated tia.
  2. Spencem
    Spencem
    Oct 15, 2001
    197
    Northampton
    +9
    Sorry to state the blindingly obvious, but shouldn't you have asked this BEFORE you placed the order?
    Use the search button on the top right of the page and you should find a few posts, but bear in mind that most people will only post about bad experiances, not good ones.
    Good luck on Wednesday.
