Am I Going Mad?
Rasczak
Am I right in think that when watching Sky+ (or Sky Digital for that matter) when you press Select on the handset you normally get the channel/programme bar appear (the one that appears for a few seconds when you change channels)? My unit has stopped doing this when I just press 'Select' (assuming I'm not going mad) - anyone got the remotest idea why it would stop displaying this? It still appears when I change channels!
Starburst
Well I never:)
Mine does display the S&S banner when you press select, wasn't aware it did that.
Have you got the S&S banner timeout set to 0 seconds?
Rasczak
Cheers Starburst - that's precisely what I had done - must have happened by accident when I was changing some other settings.
boltoa
In the interests of pedantism :), I should point out that if you're watching a recorded program on Sky+, pressing select brings up the windy wheel playback graphic with the number of minutes elapsed. Which is quite handy sometimes.
Andrew
