Am i doing this right?
Discussion in 'TVs' started by mojoicus, Sep 6, 2005.
  1. mojoicus
    mojoicus
    Feb 15, 2005
    89
    Right the tv Sagem AXIUM DLP D45S is coming on Thursday
    As it stands im gonna have the pioneer 444 dvd player connected to the tv with an IXOS scart lead
    Telewest cable box is gonna be connected with a standard scart cable(do i need a better quality one will it make any difference to the cable signal picture quality)
    Pc is gonna be connected via dvi-d cable
    pc sound will be using an optical connection to the amp for the surround system as will the dvd and tv (ill be using an optical spitter for this http://www.tvcables.co.uk/cgi-bin/t...Digital Optical Switch/op=eq.html?id=5WpkzzUP)
    What i want to know is am i doing this right any advise greatfully recieved
    Many thx
    Steve
  2. Razor
    Razor
    Dec 15, 2004
    37,548
    2
    +12,508
    Grab a decent scart lead for your sky box. :smashin:
  3. dunsters
    dunsters
    Mar 14, 2005
    303
    +7
    Upgrade the Telewest Cable scart to a good scart as the TV is such high def, IMHO it is bound to show up poor feeds and I am having all sorts of problems with my SKY+ feed.:thumbsdow
    Perhaps also, you could link the Telewest Cable to the DVD and then, from there, to the TV as anecdotally some DVDs include on-board processors that some people say it can help with picture quality from a poor feed (i am certainly going to try this out tonight too);)
    Cheers:hiya:
  4. mojoicus
    mojoicus
    Feb 15, 2005
    89
    Thx for the answers please let me know how you get on with the set up you mentioned + is scart the only way you can go with regards connection to the tv and telewest
    And what i did notice is that most of the comments remarking on picture quality and Sky is that its sky thats the problem would the problem still be the same with telewest as its a cable signal
    Many thx
    Steve
  5. dunsters
    dunsters
    Mar 14, 2005
    303
    +7
    ScartRGB is the only way for Sky at the moment. I don't know about Telewest but, if there is an option (unlikely I think), go for component RGB, as net to HDMI, this is the best connection option.
    (AV, composite, s-video, scart, scartRGB, component, HDMI/DVI)
    Cheers:hiya:
  6. mojoicus
    mojoicus
    Feb 15, 2005
    89
    Anyone else on the telewest picture quality?
  7. indie24
    indie24
    Oct 3, 2004
    882
    46
    london
    +200
    has your dvd player got component out. It will give a better picture than scart
  8. mojoicus
    mojoicus
    Feb 15, 2005
    89
    If it has which i have to check i could then move the scart lead to telewest mmm
    brb
    Thx
  9. mojoicus
    mojoicus
    Feb 15, 2005
    89
    Found this info
    As far as connectivity goes, around back you'll find one set each of component-video, composite-video, and S-Video outputs as well as digital optical and analog audio outputs
    So which cable do i need for the better picture and which do you recomend
    Thx
  10. mojoicus
    mojoicus
    Feb 15, 2005
    89
    In the manual it says
    This player features S-video and composite video output possibillities
    Now next to the S-video connection is a little yellow socket i take it that thats the composite out ?
    It also says Make composite video connections to a standard TV or monitor with a video imput jack
    use the supplied video cable to connect one of the VIDEO OUT jack on the player to the video input on the TV or monitor?????
    Exactly which cable does anyone recomend
  11. mojoicus
    mojoicus
    Feb 15, 2005
    89
    Looking at it i dont think it does think its composite which is a step back
  12. mojoicus
    mojoicus
    Feb 15, 2005
    89
    It has a coaxial connection is that the same as component???
  13. mojoicus
    mojoicus
    Feb 15, 2005
    89
  14. indie24
    indie24
    Oct 3, 2004
    882
    46
    london
    +200
  15. the_pauley
    the_pauley
    Nov 7, 2002
    4,066
    +198
