Am i doing this justice?
Discussion in 'Cables & Switches' started by cwoj, Oct 19, 2004.
  1. cwoj
    cwoj
    Hello
    Having got the HC bug big time :thumbsup: , I have for the last year been spending at a furious rate (don’t tell the waf). :nono: I have to be honest and say that am not very technical, but think I understand whats what? This is my current set up, with the exception of the svs sub and projector. Can someone please take a look at how the equipment is set up and tell me if its correct and that I am getting the most from the system? All the cables are cheap and nasty ones, except Mark Grants and the HDMI (approx 8Mtrs), so they could do with an upgrade, but to what make? Any views, comments, idea’s and criticisms are most welcome? :confused:
    Cwoj
  2. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    You haven't mentioned the size of screen as generally the larger the screen the more it will show up any defects. Certainly the DVD player could definately do with a decent scart if you are only using a freebie and I would suggest that at the very minimum you look at the Thor scart cables supplied by TV Cables here At that price I would buy a second for the Sky box but the VCR won't really benefit from more expensive interconnects
  3. cwoj
    cwoj
    The screens a 29" tosh, nothing special at the mo, although i will be upgrading in the near future poss panny ow7. I dont mind spending money on decent interconnects, i aslo need to know that i am using the best possible connections.. :laugh: So if you had a free(ish) amount, what would you blow in on? (cable wise)
  4. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    I wouldn't spend any more than on the Thor cable in the link further up. If you were to upgrade to a much larger plasma that opens up new options for you with perhaps a set of component leads coming into the picture
