MitsiTurbo
Established Member
Hey guys,
As you may have read elsewhere on the forum, I have just bought my first place. It hasnt been finished yet, but the time is fast approaching so im trying to ensure that I have everything planned. Im going to be doing a fair bit of work, so I want to get as much ready in my mind as I can!
Anyway, would probably be best if I start with one of the diagrams to show the lounge:
The lounge is the L-shaped room.
Right... I have two neighbours to consider. One below, and one next door. You can just see the edge of the one next door, which is an exact mirror of mine. The apartment below is a completely different layout, but there lounge will be underneath mine.
The apartment is a new build, but im not sure what standard soundproofing is on new builds. So thats the first thing im after some input on. The builder is Charles Church if that makes any difference. Apparantly they are the John Lewis of house builders!
I can get some diagrams showing the make up of the dividing floor and walls as that will help greatly I would expect. Im fairly sure that the floor has a layer of concrete 'board' (some sort of hybrid fibre board thing I think) and I know that the dividing wall has some sort of foam, then a large air gap and then another block of foam on the next wall.
So... my front speakers, which are Mordaunt Short 902i's, bi-amped from an Onkyo SR605, will be on the following stands:
http://www.aivn.co.uk/
Unfortunately, theres no right-clicking on that site, so I cant get the direct address for the speakers, but they are under speaker stands and are called 'S.Stands-aivn'.
These will be filled with sand or lead shot and will be stood on a piece of granite also.
The centre speaker is a Mordaunt Short 903, bi-wired from the SR605 will be on 'S.Stand-DUO' from that same site. This will also be stood on a piece of granite.
The sub is going to be (although, not bought yet) a REL Q150e MK2. It has spikes on the underside and will also be stood on a piece of granite.
Just to add, the speakers will be on the left hand side, so up against the outer wall, not in the 'L'.
The underlay will be Cloud 9 Cumulus (11mm with 43db's of soundproofing... apparantly) with carpet on top, not laminate.
So, I would really appreciate some help on whether that is enough to stop the sound passing to the apartment underneath and also, what I should start to consider for stopping the sound passing through to the neighbours lounge.
I know there are a number of threads on soundproofing, but I was hoping for some specific advice from the drawings and info I have provided.
Any help would be very much appreciated. I want to be able to have things as loud as possible without disturbing my new neighbours!
Many thanks
John
Many thanks
John
