Am i allowed to claim a new 360 or repair for damaged memory unit
Discussion in 'Xbox Forums' started by Pantera6, Jan 13, 2008.
  1. Pantera6
    Pantera6
    Jul 27, 2006
    353
    +7
    basically after not needing a memory card until now i decided to stick one in the other day to memory card slot A.
    and to my great surprise it broke and somehow unatached itself and loged itself at the back of the slot. leeaving the front of my 360 shoddy looking.
    is there anyway i can repair this myself? i havnt figured out how i can take off the front plate yet or anything.
    otherwise if its not reparable, can i bring my year and a half 360 into game and ask for a new one without being laughed at and thrown out of the shop?
    because i know it sounds really petty, but it does make the 360 look pretty bad.
    cheers
    edit: i have the receipt
  2. andytabor
    andytabor
    Jun 5, 2006
    1,446
    +35
    with a little bit of force the front should un-clip fairly easy then you should be able to remove it, just make sure you unplug it and remove any disc you thats in before you man-handle it just to be on the safe side.:smashin:
