Thanks for your help but I am going to stop posting on here now as I am so confused now and keep getting different advice from people. I think I will have to set up a new forums for dummies like me. Problem is if you ask for advice in a shop then all they do if try to over sell and not actually listen to what you want.
No problem, Im sorry you feel somewhat misled
Maybe if you say state specifically what is confusing you I can help as Im pretty clear about the issues
High Definition Camcorders HDV and AVCHD and HDTVs are commonplace. The formats are different although both Hi def
It is easy enough to play the footage back by conecting the camcorders to the HDTV by HDMI or component
Beyond that it is not as easy because unlike SD there is no
straightfoward Burn to DVD and watch it in Hi def quality option
All the current options are workarounds to enable us enjoy the HI def footage
Tape has an advantage in that you can use your tapes, and edit back to tape.
HDD or flash card doesnt have that advantage. Also AVCHD seems to be a format to which you record to in the camcorder . It is less easy( not impossible ,mind you) to retain it as such after editing if desired.
The industry is a bit slow in the provision of Blu ray and HD DVD burners ,blanks and affordable players in the manner of DVD blanks, burners software and Players. It is probably due in part to a feeling that people will learn to copy original copyrighted Hi def software, and due to the inference that people just want to watch footage off the camcorder computer or internet.. What ever the reason they are not very willing to speed up the development of domestic affordable Playback media and burners
Perhaps you can say what advice you have got which is contrary to the above.
Im just a bit unhappy that when the kit is advertised or sold all this is not mentioned.
Have a think about it . if the hassle is too much you can return it for now keep an eye on events and then buy later when things are a lot less muddled as they seem to be now
