Lighty
hi guys
my MIL would like a DVD recorder with HDD, but she's not too tekky and needs something east to use.
I have a panny ex85 which she's ok with so something similar could be good
the main issue though is slightly odd ....
she'd like to be able to record on the hdd and then either watch in the front room or the portable in the bedroom.
can the dvd recorder be set to out put 2 signals simultaneously?
i could probably run a 10m or so cable from the source to the bedroom to do the job if possible.
any dabling in the menu to change svhs - scart / etc would probably be a nightmare!
obviously if she records to hdd then it makes it difficult.
I guess another solution is to record to dvd ram and get 2 cheaper panny recorders......
thanks
lighty
thanks
lighty
