Alternatives to TU-PT600
Discussion in 'Plasma TVs Forum' started by hhb97b, Nov 4, 2004.
  1. hhb97b
    hhb97b
    I have my eyes on the Panasonic 42pw6/7 or 42ph6/7 (little too expensive) , but these models don’t have build in tuners. So I was wondering what the best tuner is to see analogue TV on these plasmas. I know Panasonic has one TU-PT600, but what alternatives are there and what would you recommend? I have considered different solutions
    1. Use the tuner from a video.
    2. Make a htpc with a Hauppauge PVR-250 and use dscale
    How will these alternatives compare to TU-PT600 – will the picture be worse or better?
    THX
