Cherrywood
Established Member
We are due to start our Living room/ Home Cinema room build and starting to buy all the equipment.
TV – LG 49UF690V
Projector - Epson-eh-tw6600
Projector Screen – Home gear 100” Motorised IR Screen
AV Receiver- ONKYO TXNR646
Logitech Harmony Ultimate Hub (open to other suggestions)
We are having 8-12 downlights installed also. Originally I looked at getting the Phillips Hue range but at £50 per bulb, its out of the budget right now.
Ideally we would like to use something similar to the Light Wave range so we can have the Light & Power Sockets all managed by Wifi but have since found that the Logitec Harmony does not support them.
What alternatives do we have?
Should we save and wait to add the Philips Hue (not fussed about the colours etc. just want On/Off & Dim)?
What alternatives do I have for auto lighting that works with Harmony Hub?
Is there better Universal remotes that we can use alongside the above?
Thank
TV – LG 49UF690V
Thank
