Alternative Way Of Connecting Pw7
Discussion in 'Plasma TVs Forum' started by Wild Rumpus, Jun 6, 2005.
  1. Wild Rumpus
    Wild Rumpus
    Mar 30, 2005
    138
    Erskine
    With the latest offer prices I'm considering a purchase of a 42PW7 panel at the moment and I know that the general advice is to use the JS RGB-VGA converter for SCART. However, I have a Denon 3805 receiver which can switch component inputs. I was considering using the JS RGB-Component converter for my Freeview box and taking the output from this, along with component feeds from my DVD player and DVD recorder, to my receiver. I would then take the output from the receiver to a Component board on the PW7.
    This has the advantage of only needing one signal cable going to the panel (and only one input board) with combined audio/video switching.
    Any thoughts? Is the JS RGB-Component converter any good?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    sounds ideal and the JS RGB>YUV transcoder is very good
  3. Wild Rumpus
    Wild Rumpus
    Mar 30, 2005
    138
    Erskine
    Excellent, thanks for the answer HD. :D
  4. G-man.au
    G-man.au
    I agree. That is exactly the way I have my wiring setup too. I also have the JS box as well.
