alternative to xbox live?
Discussion in 'Xbox Forums' started by H4r7y, Jun 4, 2004.
  1. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    am i right in thinking that there is an alternative to xbox live? basically a free tool to get on line directly with the xbox?
    and anyone got any experience about getting an xbox or ps2 online with aol?
    cheers
  2. colesy
    colesy
    Dec 28, 2001
    729
    +16
    Have a look at http://www.xbconnect.com/
    You need a PC to run this though and you need to open ports on your router (if you have one). Any game that has a system link option or live should work on here.
    There are a few other programmes like xbox connect,but try this for now.
  3. matiano
    matiano
    Thats the program to go for, as it seems to be the most popular meaning u will have the most people to play against. U can also play games like Halo online, although it doesnt run perfectly and is nowhere near as polished as the XBL servive but at least its free and online!
