Alternative to Pio DV 656a
Discussion in 'Blu-ray & DVD Players & Recorders' started by mccune, Jan 8, 2003.
  1. mccune
    mccune
    i had set my heart on the pioneer DV 656a as it seems a excellent all round player, however it has no pro scan ability. As this will eventually be hooked up to a plasma i feel this is a facility that would benefit. could someone suggest an appropriate alternative.
    many thanks
  2. siluro
    siluro
    Jun 11, 2002
    435
    The Original "Garden City"
    The 656 is an amazing machine, is it just ntsc your after or pal as as well? if its just ntsc your after and dont mind it only playing region 1 disks with the ability to do prog scan then i might be able to help out there.
    cheers
    lee
  3. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    The UK 656 does not include NTSC prog scan. The 757 does (It's an extra £300 though).
    If Prog Scan is for you then check out the threads about the Philips 963
  4. siluro
    siluro
    Jun 11, 2002
    435
    Ok so no it isnt a uk machine but ti DOES do ntsc prog scan and tho it doesnt do pal the picture is better than the phillips in ntsc
