Alternative Stands FOr Q2020i
Discussion in 'Home Cinema Speakers' started by ruffbadger, Feb 25, 2014.
  1. ruffbadger
    ruffbadger
    Feb 10, 2014
    72
    11
    +5
    Was wondering if anyone is using stands other than the dedicated Q Acoustic ones for the Q2020i or if anyone had any recommendations?
  2. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,439
    I would just get some stands from Atacama instead. Something like the Nexus range are well priced and will be fine for your speakers.
  3. ruffbadger
    ruffbadger
    Feb 10, 2014
    72
    11
    +5
    Thanks for the advice
