alternative audio output? 46ld550
dankvwguy
is there a way to turn one of the RCA input jack into an output? i have a logitec surround sound system that has an RCA input on the back and figured id see if i could put it to use with the TV. i know it wont be 5.1 but itll be an improvement over the tv's output
StevieBuck
Probably not. You could check to see if the TV has a headphone output, and if it does use an appropriate adaptor to plug the speakers in to there. That would be the simplest/cheapest option.
dankvwguy
I will check this out when I am home from work. I did not think about that. The TV does have the rear side facing inputs so their may be one available there. Thank you!
The Best Movies and TV Shows Coming to Netflix in November 2020: Tom's Thumbs.
