alt preset standard in EAC/lame but still 320kbps?
Discussion in 'Headphones, Earphones & Portable Music' started by sparkymarky, Feb 4, 2005.
  1. sparkymarky
    sparkymarky
    Dec 12, 2002
    1,081
    48
    cornwall
    +32
    Got it set as above, sowas expecting final result to be around 192kb.
    However all the music files say 320kbps. Thought this was 'extreme' setting?
    How do i get it to average 192 and not 320?
  2. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    In the compression options, under the tab labeled "LAME DLL" have you ticked the "Use VBR quality"?
    John
  3. sparkymarky
    sparkymarky
    Dec 12, 2002
    1,081
    48
    cornwall
    +32
    i don't have that header option?
    all i have under compression options are
    waveform , external compression, offset and id3tag.
    I've looked in all of these and cant see any vbr option that you mention???
  4. sparkymarky
    sparkymarky
    Dec 12, 2002
    1,081
    48
    cornwall
    +32
    ah found an option but its in the drop down bitrate selector (vbr 192) which i thought is redundant and has no effect???????
  5. sparkymarky
    sparkymarky
    Dec 12, 2002
    1,081
    48
    cornwall
    +32
    right. in order to set the 192 vbr, i had to change the other option her to 'lame decoder' rather than 'user defined encoder' (otherwise there is no vbr option).
    Now all that happens is that i get a full wav rip at 1411kbps???
    whats goin on??
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,336
    Rainham Essex
    +2,433
    When I set up EAC & Lame I used This web site to guide me through the maze of settings. I found it very easy to follow and all my CD's are now ripped to 192 VBR MP3.
    Have a look and see if you can see what you have done wrong. If you can't spot the error then it might be better to uninstall and start again from the beginning.
    Mark.
  7. sparkymarky
    sparkymarky
    Dec 12, 2002
    1,081
    48
    cornwall
    +32
    thanks for the link.
    I think there may be answer though.
    When you place the cursor over the ripped song it gives the properties as 320kbps and around 5-6 mb. However, start playing it in windowsmediaplayer and it states that the bitrate is less. Some songs are 190 some are 180kbps etc.
    So it seems that is 192kbps Variable bit rate. My only concern now is the actual size of the file. Obviously parts of the songs are being recorded at 320kbps peak and i am worried how much cos i dont want excessively big files. anyone know the command to set the max at 256 while still keeping vbr??
