slammeddeluxe
I have recently bought the above Alpine header unit for my car - up until recently it has worked fine - however - it has just stopped giving out any sound from the speakers - there is however a separate sub (with built in amp) that if you turn the volume right up can just be heard but nothing out of the other 4 speakers - there is no issues with fade controls - and have looked at the manual and in general settings the IC power is switched to ON
Is there some sort of internal fuse that may have popped ?
The display works fine - shows it playing through a track but no noise ????
Please help
regards
Paul
Please help
regards
Paul
