Alpine Head Unit Problem
Discussion in 'Motoring' started by Bad Apple, Aug 21, 2013.
  1. Bad Apple
    Bad Apple
    Feb 5, 2012
    Long story short I have an Alpine iXA-W407-BT Double DIN unit in my van.
    Ive run the supplied iPod connectivity lead through to the dash and was using it fine about 6 months ago with my iPhone.
    Then for some reason it stopped playing music through it, it shows the album artwork and shows it "playing" the tracks but no sound at all.
    Ive check the volume, on my phone and on the unit, you can hear the white noise when its turned up.
    Tried a new lead, genuine Alpine again, no luck, tried an iphone lead straight into the back of the unit, still nothing...
    It plays fine through bluetooth but the quality isnt as great, I cant see what tracks playing and I cant use the video function either which annoys me.
    Anyone had a similar problem or know what it could be ?
    Gav
  2. un1eash
    un1eash
    Nov 14, 2007
    4,996
    2
    +1,416
    Have you tried another apple device to rule out the iphone?
  3. mjn
    mjn
    May 24, 2001
    23,942
    Herts, England
    +12,521
    I had a similiar problem with my Kenwood unit, turned out to be a known bug and a firmware update cured it :smashin:
  4. Bad Apple
    Bad Apple
    Feb 5, 2012
    Tried my gf's phone aswell and it does exactly the same.
    How did you do the firmware update mjn?
    With a laptop or something?
    Thanks for both your help so far
  5. mjn
    mjn
    May 24, 2001
    23,942
    Herts, England
    +12,521
    It'll vary from headunit to headunit, i just downloaded the firmware iso to CD, and put CD in headunit. It updated itself.
