Alpine cde 9881r setting radio stations
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by AndyLFC5, Sep 22, 2007.
  1. AndyLFC5
    AndyLFC5
    Jan 20, 2007
    760
    +30
    Hello, this is my 2nd Alpine, my first was a better model but went with other car, but on both, I have the same problem, when I set the radio stations manually or on auto (holding button for 2 secs) they are ok with power on but they dont remain in the memory once I have turned ignition off and removed the panel. I have to tune them all again. This is doing my head in.
    Fitted to a Vauxhall Zafira (old shape) using ISO connections
    Appreciate any help
  2. Dan Walton
    Dan Walton
    Apr 20, 2006
    162
    Basingstoke
    +3
    Switch the switched live with the permanent live. I think you'll probably have bullet connectors for these on the wiring harness for your head unit. One will be red, the other yellow. Swap 'em round!
  3. AndyLFC5
    AndyLFC5
    Jan 20, 2007
    760
    +30
    yes got the bullet connectors
    I connected the yellow to the yellow, red to red. You saying I should try yellow to red
