H
HondaS2K
I have just fitted a CDA-9885 together with the KCE-300BT bluetooth phone module. I am also connecting an 80GB iPod Classic via the KCE-422i Full-speed cable.
The problem is I'm getting a lot of noise in iPod mode which I find odd (and infuriating) seeing as that I cannot find a single reference to any issues with this setup anywhere on the net.
The iPod connection is 'daisy-chained' via the KCE-300BT (which has the proprietary DIN-like Alpine connector for the iPod in it) which is in turn itself connected to the HU via its own identical connector. This seems to be the correct way to do it.
The noise is a whistling, windy sort of thing that is audible at medium to high volume and is particularly audible when selecting an iPod command such as 'next track'. I initially thought it was a digital artifact, but a knowledgeable mate disagreed with me and thought it sounded analogue. The noise exists with or without the engine running, as it does in accessory or full ignition on.
The noise does not exist in CD or FM tuner mode.
I haven't gone to Alpine support yet because I find their websites (both here and in the US) to be a bit weak - I thought I would check here first.
My questions are as follows :
(1) Given that I don't think that this is a bad installation problem, has anyone had any quality problems with an iPod using the FullSpeed cable to an Alpine HU?
(2) Is the KCE-422i cable sending full digital signal to the HU? I would imagine that it is, seeing as that the front panel functions of the iPod are being handled by the HU (with the iPod controls completely disabled).
(3) I haven't got around to pulling the plug out of the Bluetooth module and connecting the iPod directly to the HU but that would be my next step. I am trying to avoid pulling dash components apart unnecessarily.
I would really appreciate a pointer here.
Thanks in advance.
Jon
Thanks in advance.
Jon
