I've had problems with this from day one, it initially worked but often I'm unable to connect via Bluetooth with the device. It's all connected correctly and has a good earth. The power leads are connected using the passthrough cables on the headunit.
Once it becomes hard to connect to the unit, it can normally be solved by removing the 4 pin connector for a minute or so, then plugging it back in again. It'll work for a few journeys then the issues will start again.
It's not specific to my android device, I've tried it with lots of others. it will simply just not be visible sometimes, and that will last the duration of the journey.
I'd love to hear some suggestions!
Charles
Charles
