Alphason Aragon AG94/2-s
Discussion in 'Plasma TVs' started by J-K, Mar 4, 2005.
  1. J-K
    J-K
    Feb 25, 2005
    141
    London
    +3
    Anyone got one? Any feedback?
    It says it is suitable for screens up to 43". Will it just about squeeze on a Pio 43" XDE?
    Also - if anyone has got one, how close to the wall does it sit? My options are the AV-Sales slimline fit [but have plasterboard chimney breast, so will require some work] or this stand. What would you do>
    Any pro's / con's of either of these? Apart from the £200 price difference off course!
  2. Setch
    Setch
    Jan 31, 2005
    71
    9
    I currently have my 435XDE on one of these, it took about 20mins to build the stand and another 20 to get the plasma sitting square. It looks great, but is only short term as I am going to be hanging the plasma on the wall in the next couple of months. I got it for 299.99 from shopatdigital.co.uk.
    It sits with the front of the screen about 10" from the wall and the front of the stand is about another 11". So approx 2 foot overall.
    Setch
  3. J-K
    J-K
    Feb 25, 2005
    141
    London
    +3
    You're a star! Thanks Setch!
