Alphason AG54 Rack
Pieman1972
Seen these in JL and thought would be idea to host my Yamaha Amp.....(TV will have DVD/NTL/VCR underneath so probably not a lot of room!!!)
http://www.unbeatable.co.uk/CatalogueItem_15698.html
JL's price is £85.00 but have seen a lot cheaper prices 60 quid (EmpireDirect/Unbeatable) or two shelf flavour for £84....
Main question is that seeing comments made about Alphason TV stands being quite expensive can anyone recommend a similar stand obviously capable of holding the Amp (9kg) and possibly a CD player......
Thanks in Advance.......
G
Gazza
Pieman1972
Thanks for the links guys.....the old imagination is running away - May have to have a little rethink/remeasure if I go floor mounted.....one advantage I see of the Alphason is it can be wall mounted (need to check the load though!)
creative-av
That one from Index looks good. How much weight do you think the shelves can hold? Do you think it will hold a denon 2803, dvd player and HTPC?
Steve
G
Gazza
Would think so. :smashin:
Quite a bit of space to even out the load.
Glass is quite tough.
might not take a baby elephant though :p
creative-av
Don't think I have enough equipment to weigh the same as a baby elephant!!! Although the Denon is quite a lump at 13kg!
Steve
stefmcd
Gazza said:
Looks good could be what I want, I'm looking for 2 shelves. I require it to be low ish, cause my LCD will be chest height with all the trailing wires hiding in the false wall.
I'm getting this delivered today - as a first order with the catalogue I'm also getting 15 quid off - delivery is free. I'll let u know my opinions on the build quality etc later.
stefmcd
Gazza - I wouldn't bother with the Littlewoods one - their delivery reliability is poor - been told they don't know when I should expect delivery of this item.
G
Gazza
Glad it is what you were looking for. Does the AV equipment look good in it. Doesn't look in the wrong place ( i.e. It looks like it is on a Coffee table? )
creative-av
Have only got our stereo on the top shelf at the moment. Will put the amp and dvd player on it tonight and post a pic(is there a guide on how to upload a picture?)
To be honest, my main priority was to find a rack/glass shelving that fitted into the space without having to pay over the top for it. It doesn't look like a 'proper' AV rack like the Argos Sona one but I wanted a wider, lower rack.
BTW, you can also get it in clear glass for £10 more.
Cheers,
Steve
G
Gazza
Pics would be good when you have all your av stuff on it. Uploading pics is straight forward :thumbsup:
stefmcd
Finally got mine from littlewoods - its actually a Kenmark. Looks nice - fits the look of my amp and speakers. Definitely a good choice if u only want 3 shelves.
G
Gazza
Yip ordered mine on Tuesday, when you purchased yours did you get the £15 removed from your final Bill?
When I ordered mine they say "£15 off order over £25" so with it being £59.99 expected confirmation e-mail to say £44.95 as did the original info on the web site but my e-mail confirmation bill says the following :confused:
Sub Total
£ 59.99
Cashback
£ 0.00
Delivery
£ 0.00
Total Including Delivery
£ 59.99
By the way is the glass clear 0r frosted?
stefmcd
CRap this has been reduced by 30 quid since I ordered it. Nothing I 've been sent either in package or by email acknowledges the 15 quid discount. THey did say on the phone that it will happen automatically on their system as its a first order so let's see!
Glass is frosted btw.
Pieman1972
Can anyone recommend / or have they fixed an AG54 to the wall ???
I asked Alphason and their response was "can't recommend what fixings to use as it depends on the wall" and "seek professional advice".
This answer is fair enough - however if anyone can share their experiences it would be appreciated..........
Cheers :smashin:
rags
Its dead easy to stick it on the wall. Even a DIY nob like me was able to do it.
Im attaching two pics - ones an AG34 (single shelf) stuck on the wall and the other is an AG54 (double shelf) on the floor. Wall fixings are supplied but you may need to change the wall screws depending on what material you screw into. Only two screws are required.
If you plan on using an LCD with it another thing that Alphason do for the stands is an LCD mount - basically its a normal wall bracket that attaches directly to the stands column but allows tilt and horizontal movement - it cost me about £18 extra and the TV in the first pic is attached to the column using it. It can take TV's weighing upto 25kg and can be used as a normal wallmount as well.
Its amazing how poor Alphasons website is - it doesnt even mention the wall bracket feature and the fact that you can swap the CD shelving spaces for DVD ones at little extra cost.
G
Gazza
Received Item yesterday. (see picture below)
Not bad quality for the price £44.99
May be a little big overall for me but I have been looking for ages and they all seem to be similar sizes.
Cheers stefmcd for recommendation. :thumbsup: :clap:
Will post final room layout pictures next week sometime.
stefmcd
You're welcome. I'm quite pleased and I paid 65 quid! I have nothing on the top shelf and it looks a bit daft - any ideas?
Latest News
iFi Audio launches NEO Stream music streamer with DAC
  • By Ian Collen
  • Published
Musical Fidelity launches M6x 250.7 multi-channel power amplifier
  • By Ian Collen
  • Published
Is Google set to rival Dolby Vision and Atmos?
  • By Ian Collen
  • Published
'Tizen TV by Samsung' brands coming to UK?
  • By Ian Collen
  • Published
Denon announces five new 8K AV receivers
  • By Ian Collen
  • Published
