Alphason AD3/105PB Piano Black - Any Views?
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by ash, Nov 7, 2005.
  1. ash
    ash
    Jun 9, 2005
    11,320
    +398
  2. dave_turk
    dave_turk
    Nov 4, 2005
    397
    28
    +31
    I've ordered one of these, should be delivered this week, was approx £260 delivered. I've bought it for a Sony 42" rear pro TV!
  3. golden phoenix
    golden phoenix
    Aug 29, 2005
    12,741
    7
    2
    cheshire
    +5,050
    hi ashmufc,
    They make the alphason stand you are purchasing, with and without the centre stand at rear, which you can put all your cabling through, if you buy a stand without centre pole, you can contact alphason directly, for cable tidy kit, or just buy one from whs for about 4.99!.
    looking at the link you provided, it actually says cable tidy feature" (that will be the centre stand at the rear, (although it is not showing on the pic).
    see hear:
    http://www.alphasondesigns.com/products/ad3105s/index.shtml
    hope this helps.
  4. smallmanongn
    smallmanongn
    Does anyone have any idea of the weight loading for the bottom two shelves?
    I know most units are 25Kg but I think that is with 6mm glass,is the 8mm any stronger?
    I have a Yamaha amp that weights 22kg on its own but need to put a couple of other bits on the bottom shelf as well.
  5. MikeMcr
    MikeMcr
    Jan 8, 2003
    403
    Manchester, UK
    +18
    Hi ashmufc,
    Did the stand from RGB Direct come with the cable tidy centre pole at the rear? Are you happy with it? I can't decide between the clear glass and black version.
  6. T0rNaDo
    T0rNaDo
    Sep 25, 2005
    8,481
    Essex
    +1,101
    the top glass is 10mm thick tempered glass..... can take upto a 50" plazma.
    i looked up the weight of a 50" pioneer it said its weight is 60kg
    mid and bottom shelf are 8 mm thick tempered glass.
    i have 2 of these stands here but with clear glass... 105s
    ( black proberly does look nice. but imho black will show up dust very quickly. )
    so if 10mm thick can take 60kg..... 8mm should be around 48kg ?
    in theory anyways.
