Alpha integrated amps v's DiVa A65+
Discussion in 'Arcam Owners' Forum' started by mhc, Feb 27, 2005.
  1. mhc
    mhc
    Folks,
    How do the older Alpha integrated amplifiers compare to the DiVa A65+?
    Thanks,
    Mark
  2. mhc
    mhc
    Was it something I said? :confused:
    I'm just a newbie trying to figure out the meaning of life, the universe and my hifi :)
  3. STIFA
    STIFA
    Thy are basically the same , except for changes in volume control concept and in some components.
    What this means is that diva is alpha with higher price.
    :) cheers stifa@eunet.yu
  4. Fisba
    Fisba
    Mar 8, 2005
    4
    You might think they are basically the same , except for changes in volume control concept and in some components... but this is not true. :lesson:
    Atleast the Alpha One, 7 & 8 has a Mosfet poweramp technology, while the A65+ & A75 & P75 has Darlington transistors instead. :cool:
    What comes to the sound I haven't had the chance to compare them side by side... but I guess the Divas should be better if Arcam bothered to change the technology? :smashin:
    - Fisba
  5. hossacd
    hossacd
    Jun 28, 2004
    115
    +18
    I have a Alpha 9 & 9P bi-amped and have compared them to the diva amps (also bi-amped) side by side to my ears they sound very different. The Alpha is more a smooth warm laid back sound but the DiVas is sharper faster and for me slighty on the bright/clinical side. The 9s also sound more composed at higher volumes.
    I prefered the Alpha amps for sound although the divas casing is much better built particulary the front which on the Alpha 9 feels like very cheap plastic, although the chassis is still rock solid.
    Your best bet would be to demo them side by side if possible.
